04-21-2023
07:16
07:33
04-21-2023
07:16
07:33
I own a Versa 2, I just cannot rely on the alarm, i tried every single step to troubleshoot it, restart several times, erase all data over and over, enable notifications, i went trough every single step provided on the forums and once in a while the alarm just wont go on, off course with full battery.
This is something just unvelibable for a 200dls watch. Even a 3 dolars watch will trigger the alarm just fine.
Cant tell you how frustraiting this is and how many problems gave me that the alarm wont trigger. Shame on you that after several years you couldnt fix such a simple issue.
I regret buying this "Smart" Watch so so much.
04-24-2023 07:41
04-24-2023 07:41
Hi there, @Estebantav. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. We‘re taking your comments and sentiments in regards to our products into consideration.
As our last resort, I'd suggest performing a factory reset by following the steps below (please make sure that your Fitbit device is no longer paired to your phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Test your alarms and let me know if the issue persists.
04-24-2023 07:41
04-24-2023 07:41
04-29-2023 22:32
04-29-2023 22:32
OK, i performed the steps provided but got an error "Data not cleared, sync & try again" already unpaired the device before the master reset. I try already 3 times and always the same...
04-30-2023 04:51 - edited 06-07-2023 08:27
@Estebantav Thanks for the details provided.
Please confirmed that you've tried the steps below:
If you continue having issues to pair the Fitbit device, see Why can't I set up my Fitbit device?
04-30-2023 08:32
04-30-2023 08:32
Ok so i should do the steps provided and then the master reset? Please be as specific as you can, is driving me nuts...
04-30-2023 08:44
04-30-2023 08:44
Just to let you know, once i unpair the fitbit from the device i wont show me the device from the blutooth list to forget
05-02-2023 14:23
05-02-2023 14:23
Can you please help me carry on with the troubleshoot? I asked you below to please specify the steps since i already unpair the device and then i perform a master reset but the message data wont sync keeps appearing, please help. Thank you
05-03-2023 09:53
05-03-2023 09:53
Just wanted to state that this is not solved by no means! The answers provided where not helpfull whatsoever.... "Best answer" come on...
