Versa 2 and Sense on Fitbit account
Is it possible to have the Versa 2 and Sense on the Fitbit app? Thank you
6 REPLIES 6
Unfortunately you cannot have the Versa 2 and Sense on the same account.
See Can I use more than one Fitbit device with the same account? , particularly the text in the blue box.
A bit confusing for this old gal. So I cannot have a Versa 2 and Sense on
my account and switch back and forth to check data accuracy?
I don't get the part about checking for accuracy unless you mean wearing them both at the same time.  If that is what you mean, you could do that if you had two separate Fitbit accounts, one for each.  But then you would have to keep logging out of one account and into the other.
What that reference article was about is alternating them and having the data combine in same account.
You can't have the 2 on the same account but you can create a separate new account.
That way you can wear both all the time!
Especially useful as the Versa 2 is way more accurate but not as beautiful !
Occasionally switch accounts to upload the data about once a week.
If you use it, you will have to reactivate the Google Assistant for the Sense each time you login.
I’ve had to get a replacement Versa 2 due to erratic and inaccurate heart
rate. Pondering the Sense and thought I’d switch back and forth to compare
data and accuracy. Guess that is no doable without an additional account. A
Fitbit flaw.
Thank you
You can switch back and forth, but not so easily.  Each switch you would have to go through like adding a new device and going through setup again.
