04-10-2020
06:41
08:16
JuanJoFitbit
04-10-2020
06:41
08:16
JuanJoFitbit
my Alexa app says that fitbit is offline. How do i fix this?
04-28-2020 08:14
04-28-2020 08:14
Hi @RetireBFit, due to the recent events, I apologize for the delayed response. However, let me welcome you to our Fitbit Community.
I would like to follow up and would like to know if the your Alexa app is still showing that your Fitbit Versa is offline or if the issue got resolved.
In the meantime, please check out this help article, which explains how to use Alexa on your Versa 2.
Looking forward to your response.
09-16-2020 04:07
09-16-2020 04:07
I’m facing the same issue.
what is the fix?
Regards.
09-22-2020 06:33
09-22-2020 06:33
Swipe to the left until you see Settings. Tap that.
Scrollto find Left button Tap it
Choose Alexa . This should change its status to online
10-03-2020
11:05
05:16
JuanJoFitbit
10-03-2020
11:05
05:16
JuanJoFitbit
That article was not helpful... says nothing about fixing an “offline” Alexa reading.
Thank you! That worked!
Moderator edit: merged reply
10-26-2020 14:04
10-26-2020 14:04
Did not answer my question. Still reads offline. I cannot get music
, weather, etc. please help
11-15-2020 02:12
11-15-2020 02:12
Im having the same issue, did you manage to fix it and how?
thanks!
04:51
05:16
JuanJoFitbit
11-15-2020
04:51
05:16
JuanJoFitbit
I fixed it briefly using the Fitbit app. It lasted for a few days but it's offline again. Ideas?
Moderator edit: format
Best Answer11-22-2020 19:16
11-22-2020 19:16
Was there a resolution to this? I cant get mine to show online or to stay online in the Alexa app
11-22-2020 20:16
11-22-2020 20:16
Best Answer12-14-2020 15:35
12-14-2020 15:35
Still waiting for a fix for this.....
12-14-2020 15:57
12-14-2020 15:57
Best Answer12-14-2020 17:33
12-14-2020 17:33
It's been bugging me, too.
From what I can make out the fitbit app must be running else the device shows as offline in the Alexa app.
This seems to work for me.
01-05-2021 06:35
01-05-2021 06:35
What worked please, my is doing the same thing
Best Answer02-04-2021 12:22
02-04-2021 12:22
How did u fix issue? On my alexa app shows online few minutes then offline again
Best Answer02-04-2021 13:48
02-04-2021 13:48
Best Answer02-05-2021 15:39
02-05-2021 15:39
I just spent an hr with chat Fitbit and nothing resolved. Basically you can’t use Fitbit with Alexa. So don’t try
Best Answer05-23-2021 09:41
05-23-2021 09:41
That didn't work
Best Answer07-06-2021 10:34
07-22-2021 09:50
07-22-2021 09:50
Same issue for me. Everything else is online but my Versa. It has shown online once since I got it over a month ago.
