03-29-2020
02:26
04:18
DavideFitbit
03-29-2020
02:26
04:18
DavideFitbit
Hi,
In Uk our clocks went forward today. When I look at my heart rate on my Fit-bit app it appears to be one hour ahead-can this be adjusted to the current time?
03-29-2020 11:28
03-29-2020 11:28
Go to your tracker's Settings at Fitbit.com, scroll down to Time Zone. Set it correctly and scroll on down to Submit and then sync your tracker.
03-29-2020 11:35
03-29-2020 11:35
03-29-2020 11:41
03-29-2020 11:41
Are you certin you clicked on Submit when you were through and that your tracker did, in fact, sync?
03-29-2020 11:44
03-29-2020 11:44
03-29-2020 11:48
03-29-2020 11:48
Try a Restart and do it several times if necessary.
03-29-2020 11:50
03-29-2020 11:50
