01-17-2023
13:17
07:48
01-17-2023
13:17
07:48
Have not even had my versa 2 for a month. Was 100% last night when I went to bed an was 60% when i got up and tonight not even 24hrs later its at 20% and needing charged again?
01-20-2023 07:49
01-20-2023 07:49
Hi there, @Alib74. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2.
As for the battery draining too fast, please note that as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or the Always-On display. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
Hope that helps.
01-21-2023 01:47
01-21-2023 01:47
Hi i've already done all the steps you'd suggested and turned everything off and charge still isn't lasting??
