03-03-2024
18:11
13:11
JuanFitbit
03-03-2024
18:11
13:11
JuanFitbit
My Versa 2 has been working well for over 3 yrs until I upgraded to the latest firmware a few weeks ago. Since then, the battery that used to last 4-5 days barely survives 10 hrs. Is someone else suffering from the same issue ?
I've filed a case ID with fitbit customer service and followed the trouble shooting steps (drain to 0%, charge to 100%, then restart ... and repeat twice), but that hasn't made a difference. This is starting to feel like Fitbit/ Google forcing premature hardware obsolescence with a 'nefariously designed' firmware. Fitbit now says they will revert with 'warranty options available', which seems to be a thinly veiled pretext of saying - 'Your watch is old, sorry it's not covered under warranty anymore ... yes, we've bricked it with our firmware but we won't let you roll back to the earlier firmware, so just buy a new one'. Hope Google remembers not to be evil .... will post updates here.
Moderator edit: updated subject for clarity & removed personal information
03-03-2024 20:18
03-03-2024 20:18
Hi @DepinderS - have a look at other posts with similar issues.
If the firmware update failed in some way a new factory reset and setup may help.
If you are out of warranty they may offer you a discount on a more expensive watch which doesn't have all the features your watch has.
03-04-2024 07:10
03-04-2024 07:10
I'm going through the exact thing. I changed from the charge version to versa because I was having problems, now with this one. I'm about done with Fitbit and they just don't care.
03-05-2024 03:29
03-05-2024 03:29
Hello
same thing for me. Latest update has ruined my battery life. My Versa 3 is only 6 months old and it gave me 8-10 days battery life. Now it runs out every 2 days. Annoying!
03-05-2024 14:07
03-05-2024 14:07
Thanks Guy_, I've already attempted the factory reset a few times and that hasn't helped.
In response to my Case ID, Fitbit emailed me a 35% discount code for on one of their products "to keep you in the Fitbit family and working towards your goals", but completely missed giving me an explanation on why this firmware update has impaired the battery life so drastically. The 35% helps, but Fitbit's response would have felt a lot more sincere had they cared to explain what went wrong with the firmware update in the first place. I wonder how many other users are impacted and if fitbit is proactively mailing out discount codes to all impacted users or only to those who have 'formally' raised this issue by submitting a Case ID.
So, at this time, I haven't made up my mind if I should give Fitbit another chance or move to another tracker (even if it's more expensive). Suggestions welcome!
03-05-2024 18:03 - edited 03-05-2024 19:14
@DepinderS - thanks for the feedback, please note to avoid disappointment the discount is only available on the later more expensive models which don't have all the features your watch has, for instance they don't allow any extra apps and have a different interface and navigation.
03-05-2024 18:32
03-05-2024 18:32
Hi @SAdelaide - as your watch is under warranty it can be replaced with a refurbished one if necessary.
Though if it is working normally otherwise it might be a good idea to troubleshoot just in case there is something else coincidental which is causing the higher battery drain that can be resolved.
Best Answer03-06-2024 08:41
03-06-2024 08:41
My fitbit versa was fine until about a week ago. Updated and it was turning on and off randomly for no reason. Battery drained twice. On the third time I was not close to my charger. When I got home...it was dead. Put on the charger and still after 2 full days on charger. Still nothing. No happy
03-06-2024 14:12
03-06-2024 14:12
Yep, same here. I've had mine 13 months - it definitely isn't old by normal standards. They bricked my last one after 2 years, gave it to a friend who had no intention of setting it up, she just wanted to track her steps. One day she tried setting it up and wouldn't you know it -- works perfectly! Total BS.
But yes. I noticed about a month ago my battery was draining faster than usual. Now I'm lucky to get 24 hours between charges. Absolutely ridiculous!
03-06-2024 19:38
03-06-2024 19:38
03-07-2024 05:33
03-07-2024 05:33
I'm having same issue started 3 days ago I can't sync my fitbit with my phone now either
03-07-2024 06:53
03-07-2024 06:53
My battery seems to be draining quiet quickly as well. Was fine yesterday, but now seems to be draining very quickly. Today it's gone from being 90% charged to 42% charged in 7 hours.
03-07-2024 16:29
03-07-2024 16:29
My Versa just died - won’t take a charge and shows no sign of life. Is a battery replacement possible ? Who can open it up and fix. I’ve had it for a few years and clearly seems to involve some of the new software.
Gary
03-07-2024 16:47
03-07-2024 16:47
Best Answer03-07-2024 20:36
03-07-2024 20:36
Hi @G-Bruce - unfortunately watches aren't repaired, partly because of the cost of doing it is so high, and partly because of finding what has caused the failure (it may not be a simple battery problem) and getting the correct parts, there is no certainty it will work properly afterwards.
If the watch got water in it the damage may be too extensive.
If the software failed it will need a new engine.
Best Answer03-08-2024 07:30
03-08-2024 07:30
Thanks, as part of the initial troubleshooting, I went into the settings and changed them back to whatever conserves battery best, but no joy ..
Most relevant ones were Brightness (I lowered it from 'Max' to 'Normal') and the Always on display (set to 'off' now). Despite this, the battery is still not back to the pre-firmware update levels. Max I'm able to get out of it is 10 to 12 hrs.
03-08-2024 07:46
03-08-2024 07:46
@DepinderS - thanks for the update.
With such a short battery life after a factory reset it is likely the watch has hardware damage.
There are no settings to improve that. Beware of it getting hot, either wearing or on charge, as the excess used battery energy hss to go somewhere.
Best Answer03-08-2024 07:49
03-08-2024 07:49
Guy, I hear you. But the issue here is fairly simple - my battery used to last 4-5 days before the firmware update but doesn't give me more than 10 to 12 hrs since the firmware update. All other variables remain unchanged - no water damage, no mechanical damage etc. I think it's fair for Fitbit / Google to acknowledge that their firmware is wrecking battery performance, either intentionally or unintentionally and address this transparently and sincerely. What I see them doing instead is covering their culpability by offering a 35% discount or looking for peripheral excuses and recommending troubleshooting steps that have already been performed (and already reported in the original Case ID). Be honest and own up.
03-08-2024 08:00
03-08-2024 08:00
@DepinderS- just to be sure, what is the firmware version in the watch and app version, which can be found:
Watch Settings, About Versa 2, System info
Fitbit App, Help & Support section
It is not impossible the Fitbit App can cause an issue and to isolate it, sync the watch then turn off the phone's Bluetooth, charge and restart the watch, and see how long the battery will last.
Note how long it take to charge the watch and if it gets hot.
Best Answer03-08-2024 11:20
03-08-2024 11:20
@Guy_ I'm curious too. The face came loose on my Versa2 a couple Months ago and I've been using up a Versa 1. From some of these posts, it would seem the Discontinued Versa 2 had a new update?
