05-02-2021 18:43 - last edited on 05-03-2021 14:04 by LiliyaFitbit
I have made no changes to settings and my Versa 2 suddenly drains battery after a few hours. Help!
06-13-2021 19:25
06-13-2021 19:25
Hello everyone, thank you for your updates in this thread. For all of you who are new to the Fitbit community, welcome!
Thanks for the details shared in your posts. I understand how you are feeling about this situation and appreciate your troubleshooting efforts. If you're using an iOS device, please keep an eye for any update for the Fitbit app and make sure to download it once you see it available in the App Store.
See you around.
06-13-2021 22:08
06-13-2021 22:08
Well, I’m back. Two and half weeks and it’s the same problem. I’m currently charging my Fitbit for the second time TODAY as it was completely dead.
FYI, I’m on an iPhone X running iOS 14.6. Please - do something about this.
06-14-2021 06:30
06-14-2021 06:30
I found that if i turn off Bluetooth for Fitbit only in my settings but keep Bluetooth on for my phone that it will still deliver my notifications (texts and anything else I linked) and not drain my battery. I have to go into my settings to the Fitbit tab and turn on to sync my steps and minutes but this has worked for me the last week. My battery was last fully charged Wednesday and was at 40% this morning. The only thing is, if you forget to turn it off once synced - it’ll drain fast. I synced at 8:45 AM and forgot and it jumped down to 15%
06-14-2021 13:51
06-14-2021 13:51
Ok, this-losing-battery-in-an-hour thing is not going to work for me. I hope this isn't some kind of trick to get us to purchase new devices. If I have to do that, I will for sure be switching to Apple Watch. Booooooooooooooo fitbit.
06-28-2021 07:41
06-28-2021 07:41
Been happening for weeks for me too with my Versa. I’ve given up and have an Apple Watch arriving today; so after nearly 8 years with Fitbit I am going to something else. I tried all of the suggestions except turning off Bluetooth syncing because that defeats the purpose for me. Because I can’t always look at my phone, I rely on my smart watch for a quick glance of if a message or call is important (in addition to fitness, sleep, and heart rate tracking). This isn’t meeting my needs anymore and I am very frustrated. I tried to wait it out and have checked for a software update daily without one ever being available. Having to let my Fitbit sit on a charger multiple times a day just doesn’t meet my need.
07-04-2021 07:45
07-04-2021 07:45
I've recently had the same problem. I swam with it 2x for about 10 minutes, and now it won't hold battery life for 12 hours, I used to go 3 to 4 days before charging. Never changed any settings, and I've only had it since January 2021.
07-12-2021 10:43
07-12-2021 10:43
update: contact support and they offered a warranty resolution and I sent the watch in on 6/10. The shipping ticket was theirs - split ship with pickup /drop-off with USPS first. My trace says accepted by USPS on 6/10 and then pickup by carrier on 6/11 at a nearby PO. The traceability stops there. I sent an inquiry to support as to the status. Yep -- i got an answer which I leave to the audience if that is appropriate "thanks for letting us know that your device was shipped, we'll let you know once it is processed ". ok FITBIT -its getting close to 2 months from initial problem to "device is somewhere in the only Fitbit can track and know ether" so am I out of line or lack patience on this ( 2 months without a device ? ) really - do i need to go the route of researching other products out there and do cost -value analysis. Warranty sucks when it is needed and used, sucks even worse when you don't know what's going on. FITBIT - please tell me that you know where my device is...is it still with carrier, with you and if so why so so long. It like you are a good friend that wants to part ways. I have had Fitbit since you were young and have an Aria. Lets not get to that point of separation. I need resolution. so does the community. did i read that there was an update released or an Apple update ? I hope for those out of warranty or those that just want resolution that the fix is in the pipeline. Lil Bo Beep has lost her sheep ( because .....
07-12-2021 13:04
07-12-2021 13:04
Can you share what you did? factory settings of the fitbit or phone?
07-12-2021 13:17
07-12-2021 13:17
07-12-2021 13:23
07-12-2021 13:23
07-12-2021
14:17
17:58
DavideFitbit
07-12-2021
14:17
17:58
DavideFitbit
If you can't use it as a smartwatch, what's the point of having a Fitbit Versa?
I've just got a replacement watch sent as my old Versa Lite had developed issues and I'm shocked to see it's not holding the charge.
Are FITBIT working on resolving this issue?
Hi Liliya,
What is FITBIT doing about resolving this battery issue?
As mentioned by someone, the only way to prevent the battery from draining fast seems to be to take the watch off bluetooth. This means you can't use it as a smartwatch.
What's the point of having a Fitbit watch if you can't use it as a smartwatch?
Please give affected users some indication of when this issue will be resolved.
Many thanks.
07-12-2021 14:44
07-12-2021 14:44
07-12-2021 19:31
07-12-2021 19:31
Mine is doing the same thing… charge and maybe get an hour!!!
07-12-2021 19:58
07-12-2021 19:58
So I read through this entire thing and my Versa 1 also had this issue at the exact same time.
I set my brightness setting from auto to DIM and also did a factory reset.
Good to go. Hope this helps for you all! No need to turn off bluetooth.
07-12-2021 20:51
07-12-2021 20:51
07-13-2021 04:49
07-13-2021 04:49
This morning, for whatever reason, my Versa light is behaving better again. No massive drain on the battery like yesterday. Haven't changed any settings. Here's hoping.
07-13-2021 08:12
07-13-2021 08:12
same with me. It says 0% charging even while on the charger.
I asked the customer consultant if it might be the battery and they shift away from giving any answers that are helpful.
07-13-2021 14:02
07-13-2021 14:02
You are very welcome.
Here is the way I did it and maybe this will help others as well:
My conclusion from this set of steps is that there was an update that didn't take on a lot of peoples older Versas and was causing a conflict thus pinging the watch more than it should, draining more battery because of it. I am now happily getting 20% of battery a day on the Versa 1(which is normal) this will be better on the Versa 2 as it has a better battery. Somewhere along the line, an update got botched and it gets stuck in a loop thus needing the entire watch to be reset to to factory to really take the new update. Doing this allows the watch to skip any bad software updates and skip directly to a working one. Hope this helps
07-14-2021 18:23 - edited 07-14-2021 18:32
reply to post of Tristannyc : What you did and how you explain it makes a lot of sense from someone who
knows a bit about software, and updating devices. I would recommend that
others try this approach and let people know what their experience is. as
for me, well - still no word back from Fitbit on what their carrier did
with it or their 3rd party recovery service. I just seem to be SOL for 2
months now. put my old seiko back on and looking at how i might be able
to fix my Blaze.
Thanks for posting this - I hope this is the Solution. ( Factory reset,
Forget everything and Start as if you never had a Fitbit -except for the
account )
07-14-2021 18:30
07-14-2021 18:30
to fix my Blaze.
account )
