Versa 2 can not swipe and will shutdown and restart.
My versa 2 is intermittently not working. I should say it sometimes works. It will not allow me to swipe to a different screen or app. I can hold the button and restart it and if i do it enough times it will start working for a little while. It then stops working again. It has also been shutting down and restarting on its own. It also seems to take a long time to sync to my phone.
1 REPLY 1
@ISPY_Tycoon At this point, I would attempt a factory reset (restoring the tracker to factory defaults).
As you have problems swiping, you can try using the back button:
  1. Hold the back button for about 8 seconds.
  2. When the Fitbit logo disappears:
    1. Release the button briefly (for less than 2 seconds).
    2. Hold the button again until you feel a second, longer vibration, which indicates you initiated the factory reset.
You can set up the watch back to the Fitbit account by following the instructions on this link: How do I set up my Fitbit device?
If you're not successful with the factory reset, I am afraid you will need to reach out to Customer Support to guide you through the next steps. Here's the link to Customer Support page.
Marrrmaduke | Canada
Charge HR, Blaze, Charge 2, Charge 3, Inspire HR, Versa Lite, Versa SE, Aria
