02-27-2020 12:54
02-27-2020 12:54
unlike the Versa (in which has a flat bottom and side cord) - The Versa 2 has the charging cord is coming out of the bottom of the charging station, which doesn't allow for it to lay flat - instead you have to place it awkwardly on the side....Is this normal? is my charging station missing something or do I need to order a separate piece to hold it?
02-27-2020 13:36
02-27-2020 13:36
Yes that is the way Fitbit designed it,
02-27-2020 15:33
02-27-2020 15:33
ok thanks. but do you know if there is there a work around solution to make it sit flat on the table?
02-27-2020 20:09
02-27-2020 20:09
Maybe this was the intent of the weird design.
--Ariel
02-28-2020 00:13
02-28-2020 00:13
I guess you could rewire it. Not sure what the big gal is.
