01-15-2020 07:19
01-15-2020 07:19
The weather does not show up on clockfaces when downloaded. I’ve tried several different ones. The weather works when you go into the actual app but it does not appear on the clock. I saw that the versa had problems with this also. So has anyone figured out how to fix it?
01-15-2020 07:26
01-15-2020 07:26
Hi @LeftyLouWho , if you download a CF that should show the weather, make sure that Accuweather is the API/provider, since that is the one Fitbit uses. If the CF does not use Accuweather, you will not see the weather on your watch. Regards kuzibri
Best Answer01-15-2020 08:13
01-15-2020 08:13
Best Answer01-15-2020 08:17 - edited 01-15-2020 08:18
Hi @LeftyLouWho , normally you will find it in the description of the Clock Face, f.i. this Clock Face uses Forecast, etc. Usually it's on the bottom of the description page. regards kuzibri
