12-24-2020 15:13 - last edited on 12-25-2020 15:28 by LiliyaFitbit
Any clock faces that show alarm status?
12-25-2020 08:59
12-25-2020 08:59
Hi @Mannbrad - I did not have any luck in finding a clock face that shows alarm status but I am currently using the Versa 3, not the two. What I suggest is this: From the app on your phone, tap Account -> Versa 2 -> Clock Faces -> All Clocks. From there, you can search for “Alarms” or “Alarm Status.” Hopefully something will show up for you.
But if you can’t find a clock face that shows what you want, you can make it easier to open Alarms to see the status. Tap here and go to page 17 of the Versa 2 manual for details.
Best Answer12-25-2020 08:59
12-25-2020 08:59
Best Answer12-25-2020 09:03
12-25-2020 09:03
