01-04-2021
15:27
11:48
RicardoFitbit
01-04-2021
15:27
11:48
RicardoFitbit
I'm thinking about buying a versa 2. I have a galaxy A11 and would like to know if it is compatible. I dont want to spend the money if I dont have use of all the features
01-07-2021 10:28
01-07-2021 10:28
Here's the Compatibility link.
01-07-2021 10:28
01-07-2021 10:28
01-23-2021 12:51
01-23-2021 12:51
I have an IONIC and also need the A11 to be compatible. Anyone know if Fitbit is even working on it as it is cumbersome to keep connecting to an old phone or tablet that is not with me. Plus the phone and text notifications have been lost.
01-23-2021
22:08
07:07
01-23-2021
22:08
07:07
@scuba1okThere seem to be general problems recently, if your watch was working fine and now isn't, then the problem is less likely to be either your watch or phone related, given that other are also experiencing problems.
Probably best to inform Fitbit Support directly. They may be able to help you.
01-24-2021 09:52
01-24-2021 09:52
I am able to connect my Ionic to my old phone which shows supported on the Fitbit website so the what is working fine. A11 was working just fine until this most recent firmware update. No only access to caller ID and messaging is on an old phone which is no longer carried. Need A11 to be a supported devise as soon as possilbe.
01-24-2021 10:11
01-24-2021 10:11
This is just a forum.
01-25-2021 12:31
01-25-2021 12:31
I have an A11 and my versa 2 and 3 won't sync anymore. It has worked fine for the past year and ever since the update it doesn't work. Customer service is no help. They just repeat that its my phone
01-25-2021 21:15
01-25-2021 21:15
Check the Fitbit app version
In the phone Fitbit App Click on profile photo [top left] Help & Support Version at the top |
If it is 3.36 or 3.36.1 update to the recently released 3.37, it may fix the issue.
Of course you may have to do a bit of Sync setup and troubleshooting to get things on track.
01-26-2021 05:28
01-26-2021 05:28
