05-17-2021
06:25
07:01
05-17-2021
06:25
07:01
is it possible to link the versa 2 with Samsung Galaxy s20 so it notifies text and telephone calls ?
Was able to do it with an I phone so i am thinking it should be possible
Please advise
05-18-2021 07:10 - edited 10-09-2024 08:38
Hi there, @AndrewMuscroft. Welcome to the Community Forums.
If your Samsung S20 meets the requirements to operate properly with the Versa 2, then it should work fine.
As you may know, the Fitbit app is compatible with most popular phones and tablets. To set up and use your Fitbit products and services, you must install the Fitbit app on a compatible device running one of the following operating systems:
Moving forward with the troubleshooting steps for this issue, please make sure you've removed your Versa 2 from your old phone. If the connection between your phone and watch still exists, the notifications may be coming from your old phone and that's why they are not showing on you watch.
Follow the steps below to remove the Versa 2 from your old phone and to set it up on your S20:
As a friendly reminder, know that since you're setting up notifications, you'll need to receive a message from the app desired in order for your app to show it as option in your Fitbit notification's section.
If you continue having issues with the notifications, please see Why are notifications delayed or missing?
Hope this helps.
Best Answer05-18-2021 07:10 - edited 10-09-2024 08:38
Hope this helps.
Best Answer05-18-2021 09:01
05-18-2021 09:01
Best Answer05-18-2021 09:16 - edited 09-05-2023 09:56
@AndrewMuscroft Awesome! I'm very glad to hear that the steps recommended above have done the trick for you.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
