Versa 2 connection issue with Samsung S10+
ANSWERED
When I go to run or walk, the versa just indefinitely says "searching".  At that point, if I initiate a sync from the phone, it says "connected".  This stopped working about 3 weeks ago, it seems right after the versa 2 ran itself completely dead (likely my fault rather than its).  I've tried rebooting the fitbit app, rebooting the phone, removing the versa 2 in the app on my phone and re-adding it (Samsung Galaxy 10 Plus).  None of these helped.  Any help?  Thanks - Eric
1 BEST ANSWER
Accepted Solutions
Hi there @EricFetzer, welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
Please make sure you've followed our troubleshooting steps provided here Why isn't GPS working on my Fitbit device? and also give a shot to @Guy_'s suggestion.
Hope that helps.
2 REPLIES 2
You might try this
On the phone check battery optimizations
[the options may be different in your version]
  • First go to Settings > Apps & Notification > Special app access
  • Click on Battery optimization
  • Now press the drop down menu [...] and select “All Apps
  • Click on Bluetooth and then select “Don’t optimize
  • Same with Fitbit
  • Next go to Settings > Apps  > Fitbit > Storage
  • Clear cache [not data]
  • Force stop the Fitbit app
Hope that helps.
