03-01-2021
07:58
12:49
RicardoFitbit
03-01-2021
07:58
12:49
RicardoFitbit
When I go to run or walk, the versa just indefinitely says "searching". At that point, if I initiate a sync from the phone, it says "connected". This stopped working about 3 weeks ago, it seems right after the versa 2 ran itself completely dead (likely my fault rather than its). I've tried rebooting the fitbit app, rebooting the phone, removing the versa 2 in the app on my phone and re-adding it (Samsung Galaxy 10 Plus). None of these helped. Any help? Thanks - Eric
03-02-2021 04:58 - edited 01-27-2024 12:52
Hi there @EricFetzer, welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
Please make sure you've followed our troubleshooting steps provided here Why isn't GPS working on my Fitbit device? and also give a shot to @Guy_'s suggestion.
Hope that helps.
03-01-2021 10:20
03-01-2021 10:20
You might try this
On the phone check battery optimizations [the options may be different in your version]
Hope that helps.
