01-16-2020 16:41
01-16-2020 16:41
Versa 2 counting 6 steps when I move my arm up and down
01-16-2020 16:49 - edited 01-16-2020 16:51
Hi @Jazzymic , that's normal. The way Fitbit counts your steps is by moving your arms fore- and backwards (or in your case up and down), just the way when you do like when you're walking. This is no bug in the Fitbitapp/Versa watch at all, but just the way it regognizes steps. Regards kuzibri
Best Answer01-16-2020 16:58
01-16-2020 16:58
Every time I move my arm straight r
Up not no in a direct where it could measure a distance... It adds on about 6+ steps
Best Answer01-16-2020 17:27
01-16-2020 17:27
It's the movement of your arms which are detected by the Versa. Does not matter whether is for- or backwards or up and down. Try it our for about 2mins and you will notice it. I know it should not detect up- or downwards movements but that's the way it, unfortunately, is. Regards kuzibri
Best Answer01-16-2020 18:50
01-16-2020 18:50
Basically it's not very good then... I had a Huawei one and it was spot on
Best Answer04-14-2020 13:40
04-14-2020 13:40
I agree. Mine is counting steps while I stand still flat ironing my hair. The only thing moving is my arm! If it can’t tell my legs are standing in the same place, how can I trust the accuracy of anything it’s tracking?!
