03-21-2021 04:09
03-21-2021 04:09
so I wake up early morning and go to look at my versa and it starts doing this crazy light show. Going from a white screen to a yellow screen to a green screen with flickering lines and sometimes the lines are red. So I go to my phone and try to sync it gets so far on the syncing then nothing. So I thought maybe charge my versa see if that helps, the light show stops after about 5 minutes and it syncs on my phone I decide to leave it charging.
anyway I fall asleep again and wake up a few hours later. Versa is back to normal, put back on my wrist not even on for 2 minutes and the light show starts I now have a solid green screen and nothing will change it.
my versa is less than 6months old, I’m on iphone, versa came up with an update the other day which I did; but does anyone have any clue what’s going on with it?
03-21-2021 05:47
03-21-2021 05:47
Good reporting of the problem. First step is to restart the watch
Make sure its charged properly then please restart it as described in this help article. |
If you get the chance, change the clock face to a Fitbit one, either on the watch or in the Fitbit App, if you can get it syncing ok.
Seems like this is quite a common issue. following recent updates, as it was working fine before.
In which case its probably best to inform Fitbit Support directly. They may be able to help you.
