12-07-2019 13:47
12-07-2019 13:47
Extremely frustrated. About to return this item. I've done about it everything to keep my new Versa connected to my phone- uninstalled/re-install the Fitbit app, shut my phone off, turn Bluetooth on and off, factory reset my Versa2... . Yes I have the option of always stay connected/synced . enabled. Still nothing. Please help. About to return item and switch over to something else. I've used Fitbit before my versa 2. I would hate to switch over to something else. Help!
12-09-2019
08:30
04:04
12-09-2019
08:30
04:04
@Zee12 Welcome to the Fitbit Community! I hope you're doing well! Sorry for the delay in my reply.
Sorry to hear that your Versa 2 doesn't stay connected to your phone and thank you for troubleshooting this issue. Which phone are you using? Is it compatible? Let's try refreshing the link between your phone and your Versa 2 by doing the following:
Let me know how it goes.
12-26-2019 17:26
12-26-2019 17:26
Hello,
I have an LG V20 phone . I have restarted the Versa 2 and phone but there are still times the watch doesn't stay synced to the phone. I checked permissions and they are enabled.
05-07-2020 17:48
05-07-2020 17:48
I had the same problem and did all the troubleshooting recommend. I was fiddling with anything I could and went Into the setting under apps and Fitbit. My phone had options for GPS on while app is In use. That is what mine was set too. Had to change it to always run gps for Fitbit app. Fixed the problem. I was ready to return mine so maybe it might help you.
