08-11-2023 11:26
08-11-2023 11:26
Three days ago my battety starting draining quickly. Now, the time is off and my sync doesn't work. Help!
08-12-2023 13:51
08-12-2023 13:51
Good to see you for the first time in the community @erindod.
Thanks for sharing the inquiry about your Versa 2.
Let me know please if you have seen the steps suggested in this article. Please, try to restart your device.
Best Answer08-15-2023 11:00
08-15-2023 11:00
It won't even turn on anymore. Ideas?
Best Answer08-16-2023 09:04
08-16-2023 09:04
Thanks for the response @erindod.
If the device is not turning on please can you check the following article: Why isn't my Fitbit device's battery charging? Did you try to perform the restart?
Best Answer08-18-2023 07:22
08-18-2023 07:22
For the past few days the battery for my versa 2 has also been draining battery quickly. At first I thought it was because I had changed the clock face so I removed the clock face. My versa has not gotten wet and I have done nothing else different to it. The fitbit app is up to date, there was no notification of a firmware update, I have shutdown and turned back on my versa 2. Why is the battery still draining quickly?
