07-14-2023
21:05
08:58
07-14-2023
21:05
08:58
My Versa 2 has a frozen screen but it will not reset. Message now Reset Failed and you can't acknowledge the okay message. I did a text message to support at Fitbit but no fix. My question is can it be fixed or is it dead? Not buying another at this point!
07-16-2023 22:30
07-17-2023 12:50
07-17-2023 12:50
07-20-2023 17:13
07-20-2023 17:13
Irish1369….. I am having this issue also, including can’t hard reset and LOOPING “ to start “download the Fitbit app”, even though I have done so several times and have also been on YouTube and tried suggested ways and NOTHING works.
07-21-2023 11:43
07-21-2023 11:43
I understand so flustered! Not buying another until I see which direction Google takes with Fitbit. I have thought this might be a Google issue...
08-16-2023 12:08
08-16-2023 12:08
Exactly what has happened to me and I have also done all the same things but still getting fail reset message, grrrrr defo something happened with all these versa going down
09-14-2023 12:23
09-14-2023 12:23
I am beyond frustrated! I am having the exact same issue. Help center was no help. They more or less suggested I buy another fitbit at a discount. I'm done. After 3 fitbits I will be looking elsewhere!
09-15-2023 08:20
09-15-2023 08:20
His problem is that it won’t reset.
10-11-2023 12:20
10-11-2023 12:20
Hi. I'm now having the exact same issue. I have tried the fix suggested several times with absolutely no effect. I still have the data not cleared message and can't get passed that screen. No help or support available it seems. And no admission that this is a complete product failure.
