05-10-2020
05:19
07:48
05-10-2020
05:19
07:48
My Fitbit Versa 2 randomly shut off yesterday and I have not been able to get it back in since. I have only had it for two weeks and has worked fine up until now. It is just a black screen and nothing will happen, it was charged Upto 70% when it turned off. Can anybody help me??
05-21-2020 07:55 - edited 10-14-2023 09:13
Hello everyone. I'm sorry for the late response.
Hey there @Jodieecclestone, welcome on board. I'm very glad to hear that our Support Team replaced your Versa 2. Thanks for your efforts in troubleshooting your watch.
Hi @elwax and @ICEPRINCESS1141, welcome to the Community Forums. I'm sorry to hear that you're going through this situation with the screen of Versa 2 smartwatches. I appreciate all the steps you've done in order to get this solved. If you're still having issues with the display or the battery, I'd recommend the steps below:
- Restart your watch as follows: How do I restart my Fitbit device?
- If your Versa 2 does not charge, see: Why isn't my Fitbit device's battery charging?
On a side note, as per the description of your posts, it seems that your watches have insufficient power source. Where do you charge your tracker? Have you checked if by any chance the USB port or outlet is faulty? If you haven't done so, try a different port. A UL-certified wall charger will also work. Don't use a USB hub.
Here are some of the best tips to charge your Fitbit:
For charging purposes, your charging cable can be plugged into any USB power source, including but not limited to:
If your Versa 2's battery is or keeps draining, see: Can I extend my Fitbit device's battery life?
In addition to the display of battery issue @ICEPRINCESS1141, if your watch is showing an incorrect time, sync your Fitbit device to see the correct time. For more information, see How do Fitbit devices sync their data?
Hey @Holtzmann, thanks for all your help here.
05-10-2020 06:02
05-10-2020 06:02
This happened to me also 😞
05-10-2020 06:25 - edited 05-10-2020 06:27
Have you already tried any troubleshooting tricks?
Do you have a third party clock face? First thing, try changing the clock face to the FitBit default one, or at least one made by FitBit.
05-10-2020 06:33
05-10-2020 06:33
The clock face was a default for it one. The device won’t even turn on it’s just a dead
05-10-2020 09:07
05-10-2020 09:07
Have you tried doing a restart? Here's how.
Next step would be a factory reset.
To perform the factory reset please do as follows.:
If that doesn't help, then contact customer support.
05-10-2020 10:15
05-10-2020 10:15
05-12-2020 06:45
05-12-2020 06:45
Ahh! I'm glad you're getting a new one, though. Hopefully it will work great!
05-12-2020 08:30
05-12-2020 08:30
This happened to me too on same day. I put it on charger thinking it was dead. Still nothing I waited a few hours took it off chargers try to turn on had to hold buttons for about 10 seconds it turned on and it said only 5 percent charged so I put back on charger it charged fully but now my clock is off by 2 hours and can't get it to correct time 😡
