05-08-2020
01:56
07:12
05-08-2020
01:56
07:12
I got this watch 4 days ago. On the first night of wearing the watch to sleep, it tracked my sleep information, my sleeping stages, and gave me a sleep score. However, the past two nights that I have worn the watch to bed, it has tracked my amount of sleep but it has not given me any information on the sleep stages or a sleep score. What can i do to fix this? Any help?
05-08-2020 02:41
05-08-2020 02:41
Ok, so this is strange as I’ve got exactly the same problem on my Versa 2 and it started rather randomly on Wednesday (so Tuesday night).
On mine I’ve noticed heart rate monitoring appears to have stopped. No recording of heart rate and no green light on the back.
Looking at my logging, heart rate monitor appears to have stopped round 12h - 13h (ACST) on Tuesday the 05th of May.
I have shut down, left off for half an hour, tried different bands and positions and even done a factory reset with no success.
And I’ve followed the instructions in the link to https://help.fitbit.com/articles/en_US/Help_article/1582
05-10-2020 05:31
05-10-2020 05:31
My Sleep Score only worked for one night. There's loads of threads about this but there doesn't seem to be any acknowledgement and/or resolution. Mine's going back
05-10-2020 06:23
05-10-2020 06:23
Have you tried changing the sleep sensitivity?
05-10-2020 08:09
05-10-2020 08:09
No I haven't. I see mine was set to normal, I've changed it to sensitive and I'll try it tonight.
Thank you
05-10-2020 09:09
05-10-2020 09:09
Of course! Be sure to let everyone know if it works!
05-11-2020 03:37
05-11-2020 03:37
Unfortunately that didn't made any difference, still no stages and score
05-11-2020 05:17
05-11-2020 05:17
Me too!!! It looks as though you now have to have "Premium." I'm so mad. This was not the case when I purchased the watch at Christmas.
05-12-2020 06:51 - edited 05-12-2020 06:52
You don't need Premium to see a sleep score. You only need premium for sleeping heart rate and a breakdown of the restoration score.
Have you tried manually adding a sleep start and end time? Since you more or less know when you went to sleep and when you woke up. What happens then?
Have you tried doing a restart? Here's how.
Next step would be a factory reset.
To perform the factory reset please do as follows.:
If that doesn't help, then contact customer support.
If you aren't getting sleep score, there's something going on.
05-21-2020 07:21 - edited 05-21-2020 07:23
Hello everyone. I'm sorry for the late response. Thanks for the details provided in your posts and for taking the time to solve the issue with your sleep data.
Hi @svb1098, @Guildo, and @Angela54321. I recommend considering the following if you are not receiving sleep stages:
Keep in mind that you must see sleep stages in order to see your sleep score information. Please swipe left on the Sleep Score graph, here you can see information about your weekly sleep average and sleep duration. To get more detailed information, see: What's sleep score in the Fitbit app?
If you seem that your heart rate is not working properly, I'd like you to perform the following steps below for this situation:
Hi @SunsetRunner. Thanks for the detailed information you've provided about your Versa 2's behavior and for following the troubleshooting steps provided in this help article. I've seen you contacted our Support Team after posting here and saw they already solved your issue.
Thanks for all your help in this thread @Holtzmann. Thanks for also clarifying what Premium is about. 😊 If you @Angela54321 have more questions about this feature, see What should I know about Fitbit Premium?
I'll be around if you have any questions present.
06-25-2020 07:00
06-25-2020 07:00
I cannot see sleep in the Today screen on the Versa 2 device. It is updated in the app on my phone. I scrolled down to he settings and sleep does not appear. The device is syncing regularly. I tried rebooting and nothing is working. I do not know where to change the sleep sensitivity. I had no issues with sleep in my Versa 1 but the buttons stopped working. I'm ready to leave fitbit all together, this is very frustrating.
06-25-2020 07:38
06-25-2020 07:38
Hi there @RoxMes, welcome on board. I'm sorry to hear about this situation. Thanks for the details provided in your post about your sleep data not showing and for taking the time to troubleshoot your Versa 2 prior to contacting us.
Would mind sending me a photo of the sleep data you get on your Versa 2 even if it's nothing so I can go from there. Also, the details you get in your Fitbit app about your sleep logs.
Besides that, I'd like to know if your Versa 2 is syncing all other data? Steps, calories, exercises, etc? If you press the button on your Versa 2, do you feel any vibration? Is the button no letting you to access to anything?
I'll be around, keep me posted.
06-25-2020 08:59
06-25-2020 08:59
My heartbeat sensor and sleep score haven't been working since mid-May. Factory reset and updates have not worked. I tried the steps that you have listed here and it is still not working. The light at the back of my fitbit isn't even turning on anymore.
06-25-2020 09:27
06-25-2020 09:27
1. There is no data for sleep,not even the category. I'm including a picture if the settings, I only get 3 categories to choose from and sleep is not one if them. By the way I also checked the "Today" app itself and it was updated April 2020.
2. I have included a pic if the Fitbit Today screen in my cell.
3. The button in THIS new device (Versa 2) works fine, the reason I had to buy it is because the FIRST (Versa Special Edition) device's buttons stopped working. Hence my frustrations, that is two devices in one year that don't work properly.
06-25-2020 09:30
06-25-2020 09:39
06-25-2020 09:39
I cannot seem to attach the pics here
06-25-2020 10:38
06-25-2020 10:38
06-29-2020 11:58
06-29-2020 11:58
I've had the same problem no heart rate , green lights on back are out . No help from fit it and this has gone on for the last 3-4weeks. I'm going to buy a different smart watch Fit bit sucks
06-29-2020 12:12
06-29-2020 12:12
06-29-2020 12:23
06-29-2020 12:23
I just called FITBIT support and because it has a 1 year warranty they'll replace it or I can get 50% off one of their other watches. Really would rather buy a Samsung smart watch at this point.
