Versa 2 heart rate sensors not working
Since New Year’s Day my versa2 is no longer tracking heart or sleep. The green sensor light is no longer on. I’ve checked HR is turned on I’ve reset it numerous times I’ve uninstalled the app. Turned blue tooth on and off and disconnected and reconnected I’ve charged the battery and nothing is working! The Fitbit is just over a year old. How can it suddenly just stop! I’m reluctant to buy a new Fitbit as I brought it as its battery lasted longer than my Apple Watch for a full shift(12hrs) now it’s not giving me any information ( basically it’s now a overpriced timepiece ) not what I purchased it for!
many other ideas as ive exhausted all what they suggest !
33 REPLIES 33
Hi @inertia5130, welcome to the Community Forums.
Thanks for bringing this to our attention and for trying some troubleshooting steps before posting over here, I understand how frustrating this matter can be for you. To better assist you with this issue, can you please let me know if the heart rate sensors of your device are still flashing or are they completely unresponsive? Did you experience this situation in the past or is it the first time? If you haven't already done so, I recommend you to check the information that's specified on our help article: Why don't I see my heart rate on my Fitbit device? and try the troubleshooting steps to fix the heart rate sensors of your Fitbit device.
Looking forward to your reply. Let me know if you have any additional questions.
Hi
I’ve never had this happen before and the green light on the back of the device is dead nothing at all flashes no recording of heart rate, sleep or daily steps per hour!
Not what I expected for a high end device from a reputable company! I brought the Versa’s 2 in November last year after having a regular Fitbit now I’m left with a glorified watch!
Please help I’ve recharged it again to see if this helps and nothing!
Therese
I'm having the exact same issue. Mine since Sunday the 3rd. No flashing in the back, heart rate monitor, no sleep monitoring.
Mine went on New Year’s Day! Thought new year maybe app needed updating but still nothing!
I
Therese
Welcome aboard @JasonD11 and thanks for your update @inertia5130.
@inertia5130 Since you're still experiencing difficulties with your Versa 2, I've created a ticket on your behalf for our Customer Support team to further assist you. Please keep an eye on your email inbox because they'll be in touch with you in a timely manner.
@JasonD11 I'm sorry to know that you're experiencing the same issue. Before we can move on, can you please let me know if you already tried the troubleshooting steps from my previous post and what was the outcome? I'll be waiting for your reply.
Don't hesitate to ask me any additional questions you may have.
Hello, yes I did try those trouble shooting options with no success. The flashing lights on the back are unresponsive. This is the first time I have had this issue
I have also been having this same issue for the past week. I’ve tried trouble shooting, even reverted to factory setting with no luck. My sensor lights stay off. And my HR was stuck at 77. Once I reverted to factory settings the HR was stuck at non responsive “- -“.
I’ve never had this problem before. This is super frustrating, as now it’s not tracking anything.
I know like me you’ve got a. Expensive watch now
Therese
Hello! Same issue here with no HR, sleep or steps per hr reporting since 6 Jan. I've attempted several troubleshooting suggestions with no success. This is not my first issue with the device in the year I have had it. Please advise.
Thank you
I am having same exact issue also!! Has anyone figured out how this is fixed yet?
Lol
fitbit have not even responded so I take it it’s a no to how it can be fixed.
mines just sitting on the table as it’s not worth wearing it if it does not do what I brought it for! Now looking for an alternative that’s not apple.
I am having the same exact problem. I have not had the HR or the green light work for a month plus now. I have tried all the troubleshooting steps with no luck.
I think this is a ploy to make us buy a new Fitbit be it the versa 3 or the other new one!
yep agreed pisses me off just a bit
Make sure you contact support.  There must be an issue with the actual devices.
My Versa 2 heart rate monitor stopped working a couple of days ago as well. It’s the first time it’s happened. There are no more flashing green lights on the underside of the tracker. I’ve tried multiple shutdowns and resets. And a factory restore. HR monitor still doesn’t work. My Versa 2 is only just over a year old. Not ok....
Fit bit are not bothered at all about it
Shame I liked them but won’t buy another
Therese
I reported an issue with my Fitbit in the 5th January. I'm still waiting for a response 😞
It's less than a month old.
I am having the same problem, as well as the SPO2 not working. This started with the latest update. I tried everything that has been suggested on the forums. Fully charged watch,  checked all the settings, turned heart off and back on, made sure I have latest update, etc.  I did everything that customer support told others that are having the same issue. I was told a ticket had been put in some time ago, and am still waiting for them to reply. Frustrated !
