02-20-2020
16:50
11:51
JuanJoFitbit
02-20-2020
16:50
11:51
JuanJoFitbit
Versa 2 - weather apps seem to plague Fitbit. Had Versa for 2 years and weather apps didn't work on it either. Brand new Versa 2 - comes from Fitbit with preloaded accuweather app. Default is temp in C. No problem, reset following myapps/weather/settings (gear icon). Surprise, F is set. Interesting because Accuweather shows C at this point.
Go back to Accuweather app, ok, now shows F for 1st city. So opening and closing app settings made it change to C. Same process (myapps/weather/settings) add City 2. Back to Accuweather app, ok shows 2nd (and 3rd) city. All in F. Life is good, until.....
******The problem / bug / feature / opportunity is that the Accuweather settings are SAVED only as long as the Fitbit app is running in the background. If the App is closed, then the settings (F, City 2, City 3 ) are lost. I don't think having Fitbit 24/7 perpetually in the background in order to "Save" settings is a solution *****
Confirm all of the below Support Team procedure from similar problem
Impression of what I've seen up the weather app: Lot easier to pull out my phone and look at the weather.... really, my weather can only be updated every 4 hours? Why would I want to know the temperature at 8 am (5 F) when it is noon and it is not 30 F. Not useful.
***************** Support Team Process ************
Made sure of the following:
Although you may have tried some steps, please try one more time to remove your watch from the Bluetooth settings, turn off the Bluetooth on your iPhone and any other device nearby, reboot your phone, open the Fitbit app and sync your Versa 2. Once that is done, check the Weather app on your watch. Please note that it can take a few minutes to see the updated list of locations.
Moderator edit: format
04-06-2020 11:49
04-06-2020 11:49
Hi @Bob303, due to the recent events, I apologize for the delayed response. However, let me welcome you to our Fitbit Community. I would like to follow up on the Accuweather issue and would like to know if the issue persists or if it got resolved.
Looking forward to your response.
Best Answer04-06-2020 20:51
04-06-2020 20:51
Juan -
no worries. events have been highly unusual
It seems that a o/s was pushed to my watch (or iphone??) that has fixed the problem for awhile, but I've since had to do a factory reset because the watch wasn't charging and after that reset haven't reloaded the weather, or set up Alexa. But I think it was working for awhile there. So might again when I take the time to set the apps up again. I'll post again if I do and whether it works.
Best Answer06-01-2020 10:12
06-01-2020 10:12
Hi @Bob303, I appreciate your response and thank you for keeping us updated. Don't hesitate to get back if you see anything unusual and I'll be happy to follow up.
