11-07-2023
09:16
05:53
11-07-2023
09:16
05:53
My Versa 2 has started being 5 minutes slower than my phone, computer and every other electronic timepiece. I see in the forums that other Fitbit users have had this problem over the years. I've tried reinstalling the app, rebooting the Fitbit 3 times, and resetting the time zone.
Has anyone found the magic fix?
Thanks!
11-07-2023 19:32
11-07-2023 19:32
Hi @Versa2user999 - did this start happening when changing to the new Fitbit App?
The good news is if it is constantly only 5 minutes slow the watch is ok, but there are syncing problems with the new app.
This may work, try Logout of the Fitbit App and swipe off the active window and in Android clear the storage cache and force stop it and then restart the phone.
Make sure there are no other devices running the Fitbit App switched on.
Restart the watch by holding the button for 10 seconds till it vibrates and the logo appears and wait for it to start.
Login and wait for any pair, link or Fixit prompts and sync.
This should enable proper syncing.
If it is still problematic in the Fitbit App App settings change to another time zone and sync then change back and sync.
Best Answer11-07-2023 19:32
11-07-2023 19:32
Best Answer11-10-2023 20:35
11-10-2023 20:35
Unfortunately this didn't work...any other thoughts?
11-10-2023 20:40
11-10-2023 20:40
@Versa2user999 - you can try changing clock face but if changing time zone didn't produce a different hour and correct minute it is still a syncing problem which may be related to the new app.
Best Answer11-10-2023 21:18
11-10-2023 21:18
