08-09-2022
18:32
07:48
AndreaFitbit
08-09-2022
18:32
07:48
AndreaFitbit
My versa is not allowing me to update it. It has been on the Fitbit logo for days. I’ve allowed the battery to drain. I’ve reset it countless times and unfortunately I haven’t made much progress. The Fitbit logo is still on the screen almost as if it’s frozen. I’ve read multiple forums on Fitbit community and I see many others have had the same issue. Please respond on how I can fix this issue. I’ve been a huge supporter of Fitbit products for years now.
08-10-2022 06:52 - edited 08-10-2022 06:57
Hello @Dianacorp
Since you have used many troubleshooting steps to try and fix the issue you can try setting your Versa 2 up again as a new device to see if that helps. You won’t lose any data setting it up as a new device but you won’t be able to save any data after your last successful sync to the Fitbit App.
To set up your Versa 2 again as a new device please follow these instructions carefully:
😃I hope this provides you with the best answer and resolves your current issue. Please come back and let me know how it went.
