02-06-2021 09:20
02-06-2021 09:20
Hello, I have a fitbit versa.
The green light sensor had stopped glowing/working.
I did a factory reset of the watch.
And now, the device wont start or power on.
Could you please help to fix both the 2 issues ? Powering on and then the sensor problem.
02-06-2021 23:29
02-06-2021 23:29
Very often a factory reset which has a bug in it will destroy the watch.
Probably best to inform Fitbit Support directly. They may be able to help you.
02-06-2021 11:54
02-06-2021 11:54
Do you see any messages at all in your Versa?
What happens when you do a restart.
Best Answer02-06-2021 18:58
02-06-2021 18:58
The versa is turned off. It is not getting powered back on, affer I did factory reset.
i tried to switch on by pressing the necessary buttons. So, I cannot restart it. Also it had sufficient battery charge, around 80%.
The screen is completely black, with no messages/indications. Also, there is no indication/notification/vibration when I connect it to the charger.
Best Answer02-06-2021 23:29
02-06-2021 23:29
