06-06-2020
06:00
04:24
06-06-2020
06:00
04:24
I’ve had my versa 2 for about a month now and it has only ever calculated my sleep score once. I can only see my sleep pattern but no breakdown of deep/rem/restoration. Does anyone know why this could be? I have “Receive sleep insights” switched on and It records the time to fall asleep/time awake/time restless. Does anyone know why this could be?
06-21-2020 04:27 - edited 10-07-2024 11:17
Hi there @Abby1397, welcome to the Community Forums. Thanks for the details provided in your post about your sleep score not being tracked by your Versa 2, I'll be glad to help you.
First of all, please keep in mind that you must see sleep stages in order to see your sleep score information. Please swipe left on the Sleep Score graph, here you can see information about your weekly sleep average and sleep duration. To get more detailed information, see: What's sleep score in the Fitbit app?
If you are not receiving sleep stages, I recommend considering the following:
In addition, please check if your Versa Lite is giving you accurate heart rate readings during the day. If you notice any inaccuracy, see: What factos can affect my heart-rate reading on my Fitbit device?
Give this a go and let me know if you do receive your sleep score in the next few nights.
Best Answer04-01-2022 01:38
04-01-2022 01:38
I’m having the exact same problem, although it has always done so before. I’ve had the Fitbit for over a year. Last night it appeared to have worked fine until half way through the night, then went into simplified mode. I removed the Fitbit and reinstalled it to no avail.
