05-28-2023 11:43 - last edited on 05-28-2023 11:47 by MarreFitbit
Not showing data on clock face of my Versa 2
05-28-2023 11:50
05-28-2023 11:50
HI there, @Melliejoe. Thanks for stopping by in the Fitbit Community Forums.
To better assist you, can I know if your Versa 2 screen is blank? If so, please restart your Versa 2 as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
If the above doesn't describe your issue and the steps don't work, is your Versa 2 only showing the time? If that is the case, please check if your Versa 2 is not set on "Always-On" as this feature will only show you the time on the main screen all the time, unless you press the button of your watch to see other features and stats. If Always-On is enable, to exit this mode, turn your wrist toward you, press the button, or double-tap the display. For more information, see How do I see the time on my Fitbit device?
05-28-2023 11:50
05-28-2023 11:50
05-28-2023 12:05
05-28-2023 12:05
06-12-2023 12:56 - edited 06-12-2023 12:59
Hi @Melliejoe. Good to see you around the community.
Thanks for the response and for performing all the troubleshooting steps.
If you are still experiencing this issue, please could you share a screenshot about this error message?
06-12-2023 20:09
06-12-2023 20:09
Hi @Melliejoe - go to the Gallery tile in the Fitbit App, click on the clock face and see all details and check you granted all permissions.
When fixed sync the watch to make sure the change is registered.
