06-20-2020
05:28
06:25
06-20-2020
05:28
06:25
I updated my Fitbit Versa 2 like the app said to and i have reset it twice trying to fix the issue. However it will not show any of the numbers or letters on the device. It has the logos from the apps like normal and the displays but no numbers or letters. How do i fix this?
06-20-2020 06:29
06-20-2020 06:29
Hi there @Jwilli17, welcome to the Community Forums. Thanks for bringing this to my attention and for taking the time to restart your Versa 2 prior to contacting us.
Since the restart didn't work, I recommend doing a factory reset but before so, please sync your Versa 2 to save all your data and then remove it from the Fitbit app. Once you've done that, do the following:
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Give this a go and let me know the outcome.
Best Answer06-20-2020 07:03
06-20-2020 07:03
Best Answer06-20-2020 08:38 - edited 01-09-2024 03:10
Hi there @Jwilli17, thanks for getting back and for the update. Did you sync and remove your Versa 2 prior to performing the Factory Reset? The error message you're receiving usually appears when you performed a factory reset without before unpairing the Fitbit. Usually you should unpair/remove your Versa 2 from your Fitbit account and phone's Bluetooth and then perform the factory reset. To solve this issue, try these steps in the following order:
If you can't get started with your Versa, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
Best Answer10-29-2020 01:57
10-29-2020 01:57
I’m having the same problem. I’ve tried ALL of this and still nothing.
