10-27-2022
07:58
03:15
10-27-2022
07:58
03:15
My Fitbit is not counting my steps. I've been walking around the office and my steps are still the same as when I first stood up.
10-27-2022 08:07
10-27-2022 08:07
Need more info...
Best Answer10-27-2022 09:02
10-27-2022 09:02
It is the Versa 2. It was working before. I thought maybe the update would help. It didn't. I tried shutting off. That didn't help. Even swinging my arms faster and higher. Didn't help. I'm getting some steps but it is sporadic. I don't understand what's the difference.
Best Answer10-27-2022 09:42 - edited 10-27-2022 09:52
Could you please check the Fitbit web dashboard and see if the steps are showing up there? Curious if there is a disconnect between the watch, app, and website where the data is stored.
Have to admit it is bit of a sticky wicket. As it started misbehaving prior to the update, then it is not the update that caused it. All that remains is the watch itself. Personally I am not a fan of doing a “factory reset” as it may cause other problems.
I guess it is possible the motion sensors inside the watch could fail, but it requires further troubleshooting.
You can also give the reboot everything a try.
There are more detailed steps from others, but that is the simple way to try it.
10-27-2022 12:15
10-27-2022 12:15
Sorry was at work. Yes the App Dashboard reads the same. But I will try your suggestions.
Best Answer10-27-2022 12:30
10-27-2022 12:30
Nope still not working correctly.
Best Answer10-27-2022 14:07
10-27-2022 14:07
As the steps are not updating on the watch it sounds like an issue with the motion sensors. As you have already tried shutting down the watch and rebooting, nothing to be gained there.
Maybe someone else has some ideas, but short of doing a factory reset I’m out of ideas. So sorry.
