06-04-2021 13:28
06-04-2021 13:28
My fully charged Versa 2 will not complete booting up. I press the side button for as long a 30 seconds and all I get is the Fitbit Logo screen but the startup / factory reset proceeds no farther. The logo screen goes out after a short while, then comes back on again. The app on my phone states the app is not connected to the Versa 2. Thoughts?
06-04-2021 23:38
06-04-2021 23:38
It seems you did a factory reset and now have a watch as you had it when you first got it, so it needs to be re-set up in the App.
Click on the Profile photo in the app and then then + Set up a Device, like when you first installed it.
Best Answer06-05-2021 11:44
06-05-2021 11:44
When setting up device I get the message that the app cannot find the device (Versa 2). Maybe I should have also mentioned that up front.
Best Answer06-05-2021 11:50
06-05-2021 11:50
Best Answer06-05-2021 11:55
06-05-2021 11:55
Try restarting both phone and watch and make sure that there are no other Bluetooth devices, watches or phones or PC's on while doing it.
Best Answer06-05-2021 19:22
06-05-2021 19:22
Hey there, does not work, tried outside house, nope, tells me I need an app (that I am using).
Best Answer06-05-2021 20:40
