05-27-2021
05:17
08:18
05-27-2021
05:17
08:18
The time is wrong, not updating anymore!
My fitbit froze then restarted it and time has been wrong since then. :s
I tried the fix location, set time zone. Nothing seems to work
05-28-2021 08:17 - edited 04-07-2024 06:43
Hi there, @Mimintoronto. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. @Guy_ Thanks for your help.
Keep in mind that your Versa 2 may show an incorrect time if it hasn't synced or has been unpaired from your Fitbit account. Your Fitbit grabs the time of the device you're syncing with. To make sure your watch has recently synced, go to your Fitbit account, tap the Today tab > your profile picture > your device image.
If your watch has been accidentally removed from your Fitbit account, please pair it again. For instructions, see How do I set up my Fitbit device?
By the way, I've moved your post to the Other Versa Smartwatches board for organization purposes.
05-27-2021 07:50
05-27-2021 07:50
It could be a clock face issue, try the following.
Swipe left on the watch and select Clocks app and choose another clock.
If there isn't one, load another clock face in the Fitbit App.
If that doesn't work go to Settings on the watch, scroll to the bottom and click shutdown, wait 10 seconds and press the button or put on charge to restart it.
Should it be a watch fault probably best to contact Fitbit Support directly. They may be able to help you with a replacement under warranty.
