12-27-2021
20:20
08:02
12-27-2021
20:20
08:02
Fitbit died. Recharged but not timr6
12-28-2021 08:09 - edited 09-01-2023 07:44
Hi there, @Strngthghs. Welcome to the Community Forums.
As @Odyssey13 has mentioned, keep in mind that your Versa 2 may show the wrong date and time if it hasn't synced or has been unpaired from your Fitbit account. Your Fitbit grabs the time of the device you're syncing with.
To see when was the last time your watch synced or to check if it's still paired to your Fitbit account, tap the Today tab > your profile picture > your device image.
If you're running into syncing issues, please see Why won't my Fitbit device sync?
Also, note that the time on your Fitbit Versa 2 may be wrong after you travel to a different time zone or when clocks change for Daylight Savings. If you changed time zones and the time on your Versa 2 is still incorrect after syncing, make sure the time zone setting is correct. For more information, see How do I fix the time on my Fitbit device?
12-28-2021 07:29
12-28-2021 07:29
Hi @Strngthghs the time comes from the device you used to set up. Sync the Versa 2 a few times and do a restart when it's charging. See if that helps get the time set properly.
