08-12-2021
08:21
10:51
08-12-2021
08:21
10:51
My versa 2 was working fine until the latest update. I attempted to add my google wallet and it would add so I removed the screen lock. The lock will now randomly appear on my screen but now my tracker keeps sending a notification that my versa is not paired and is unable to sync. I have turned bluetooth on and off and removed all other paired devices.
08-12-2021 10:52 - edited 10-25-2023 16:58
Hi there, @AngelaZierhart. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 32 before reaching out.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the steps below:
1. Remove the Versa 2 from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Versa 2.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa 2.
Hope that helps.
Best Answer08-12-2021 10:52 - edited 10-25-2023 16:58
Hope that helps.
