10-28-2022
09:15
05:28
10-28-2022
09:15
05:28
My versa 2 is showing my resting heart rate as much higher than normal all of a sudden. The increase started last week after there was an update. It doesn’t seem like it is calculating my resting heart rate correctly. Anyone else having this problem? I’m at the point, where I will be going to the dr if I can’t figure out any other reason for the change.
10-28-2022 15:42
10-28-2022 15:42
You can take your own pulse to check it, or go to most any pharmacy or supermarket that has a blood pressure/heart rate machine to check it.
Most likely the update caused some instability that may go away over time. You can always reboot or shutdown/reboot the watch to see if it clears up before taking any significant steps to troubleshoot.
