03-14-2021
18:53
05:57
03-14-2021
18:53
05:57
Hey I have been using a Versa 2 for about 2 months, it is not set up to get notification alerts from my Android phone and I have turned off any notifications that I can find. My watch is vibrating, 2 short buzzes, at random intervals both day and night, sometimes several times within 2 to 3 minutes. I don't know what else I can turn off or disable to stop these vibrations, and they are getting very annoying, especially at 3 AM.
any help or hints would be greatly appreciated.
03-15-2021 06:01 - edited 12-21-2023 03:29
Hi there @Buzzed2021, welcome to the Community Forums. Thanks for sharing the details about the inconvenience with your Versa 2 and for trying to troubleshoot it before reaching out. I understand how annoying this must be.
To better assist you with this, would you mind double checking if there are no alarms mistakenly set on your Versa 2? For more information, see How do I manage alarms on my Fitbit device?
Also, I'd like to know if you've had the chance to see what your watch displays at the time it buzzes? How long does it vibrates? Do you do anything to stop it? Like pressing the button or touching the screen? Or it stops automatically? Have you checked if your phone also has any kind notification around the time when your watch vibrates?
In addition, please check if you don't have health and wellness reminders ON. For more information, see What are the reminders I see on my Fitbit device?
Hope that helps.
Hope that helps.
03-15-2021 12:27
03-15-2021 12:27
Thanks for the reply, I have looked at the suggestions you gave and as far as I can see all alarms and notifications are off. the "buzz" is more like 2 very short vibrations lasting less than a second each time. it usually happens for example, when I get up from a chair or make a quick movement. it stops automatically, I have not seen anything display that would account for the buzzing. my watch is not linked to any apps on my phone that would account for the notifications and I have not been able to link them to anything that happens on the phone.
03-15-2021 12:39
03-15-2021 12:39
I have turned on the always on setting and so far there has not been anything displayed when the buzz happens.......
03-15-2021 12:40 - edited 12-21-2023 03:27
@Buzzed2021 Anytime!
Have you checked the health and wellness reminders? It may worth the try. For more information, see What are the reminders I see on my Fitbit device?
03-15-2021 13:27
03-15-2021 13:27
I don't see this setting on my Versa 2, I just set the do not disturb to see if this stops the problem.
03-15-2021 13:41
03-15-2021 13:41
even do not disturb did not help, still getting the vibration at least 3 to 6 times each hour
03-15-2021 13:45 - edited 09-12-2023 09:06
@Buzzed2021 At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected. I'd suggest to share this community link (thread) so our Support Team can be aware of the steps you've done so far.
