Versa 2 isn't registering my sleep
My Versa Fitbit doesn’t track my sleep. It doesn’t resister that I have slept and gives me no sleep stats. Please help
3 REPLIES 3
It's great to see you around, @Shoarau1989.
If your watch isn't registering your sleep, I recommend trying the following:
  1. Manually sync the watch. See instructions in the help article: How do Fitbit devices sync their data?
  2. Restart the Versa 2. See instructions in the help article: How do I restart my Fitbit device?
  3. Try sleeping with the unit on your non-dominant hand.
  4. If steps 1-3 don't work, I suggest manually logging your sleep to reflect the time slept. See instructions in the help article: How do I change my sleep history?
Let me know the outcome. 🙂
My Versa is not tracking my sleep appropriately either. It says that I'm only getting basic sleep data because it can't detect a consistent heart rate during my sleep. This is a relatively new issue in the past week. I've already done everything in the recommendation list above.
Hey @eyeballsohard, welcome to the Forums.
Thanks for troubleshooting this sleep stages issue. There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
  • If you slept in a position that prevented your device from getting a consistent heart-rate reading or wore it too loosely. For best results, wear your device higher on your wrist (about 2-3 finger widths above your wrist bone). The band should feel secure but not too tight.
  • If you used the Begin Sleep Now option in the Fitbit app (instead of simply wearing your device to bed). For more information on automatic sleep tracking, see How do I track my sleep?
  • If you slept for less than 3 hours.
  • If your device’s battery is critically low.
