04-05-2022
03:42
10:06
04-05-2022
03:42
10:06
Hi, My Versa 2 randomly doesn't sync my Heart Rate- steps etc are synced my heart rate not. I am also unsure of the accuracy- it tends to show 10% lower than my home blood pressure machine. From a health perspective i need to ensure both my Heart rate is tracked daily and is accurate. I re-set the watch and that makes no difference.
Thanks
04-05-2022 10:09
04-05-2022 10:09
Hi there, @Phil1966. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
If you haven't done so yet, I'd recommend the following steps:
Also, please see What factors can affect my heart-rate reading on my Fitbit device?
Hope that helps.
Best Answer04-05-2022 10:09
04-05-2022 10:09
Hope that helps.
Best Answer04-06-2022 08:57
04-06-2022 08:57
I followed your instructions to the letter, with no success. I have no lights, no heartbeat, no reason to keep trying, apparently. Sorry that there isn't a remote method to have service done to repair the Versa 2. It should be able to happen using a cradle and an exclusive secure interface limiting access only to the USB port that connects the device to the portal. Develop AI service portal and you can salvage your customer base.
Best Answer04-07-2022 05:16 - edited 11-13-2023 04:31
Hi there, @CowDaddy0. Welcome on board. I appreciate you had followed the tips and recommendations provided above. I understand where your concern is coming from.
I've seen you contacted our Support Team after posting here and they're now assisting you with this matter. Please stay tuned to your inbox for updates on your case.
We hope your issue is solved soon.
