12-07-2021
06:30
07:37
12-07-2021
06:30
07:37
Afternoon,I wear my versa 2 in my pocket or on the side of my trousers as I'm a dot.com picker for a supermarket so it doesn't pick up on my arm.
So past few days, it seems to be having me as stationary for long periods when between 6am and 2pm I don't really stop and constantly moving/walking. But I have big gaps like today apparently I've spent 2.5hrs not taking any steps at all.
Also last two nights the sleep is wrong, I was in bed at 9:30 but according to my versa I wasn't asleep till 11:30 (I definitely was asleep well before!)
Any ideas on how to fix this would be fab. Thank you in advance
12-07-2021 07:41 - edited 03-05-2024 06:39
Hi there, @Daynna. Welcome to the Community Forums. Thanks for the details provided in your post about the issues with your Versa 2. I understand where your concern is coming from.
Since you wear a wrist-based Fitbit device and move your body while keeping your arms still (or vice versa), you may see a slightly different step count than if you wear a device clipped to your clothing. For more information, see How accurate are Fitbit devices?
For wrist-based devices, it's important to specify whether you wear the device on your dominant or non-dominant wrist during setup:
To start, the Wrist setting is set to non-dominant. Change your wrist setting in the Fitbit app.
As for the sleep data, please note when your body is completely at rest and you haven’t moved for about an hour, your Fitbit device records that you’re asleep. So, keep in mind that there are some factors that may prevent your device from detecting that you were sleeping. Such as sleeping in a position that prevented your device from getting a consistent heart-rate reading, wore it too loosely or not having enough charge.
I'd recommend to sync your Versa Lite to the app after waking up. This will help to make sure that all your data is sync properly.
Also, note that your time asleep is calculated by subtracting your time spent awake and restless from your overall tracked sleep time. For example, if you slept 8 hours but woke up 2 times for 15 minutes each, your time asleep would be 7 hr 30 min.
To learn more about your time asleep in sleep stages, see What should I know about Fitbit sleep stages?
Edit or delete sleep logs in the Fitbit app. For instructions, see How do I add, edit, or delete Fitbit data and activities?
