Versa 2 isn't tracking my sleep times accurately
It records all my sleep stages but my sleep start and stop time is not accurate. Shows me waking up sooner than I actually did.  I’ve had this watch for many years and am not doing anything differently that would affect my sleep times.
2 REPLIES 2
Hi there, @Dina5018. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2.
As a first approached, I'd recommend to sync your Versa 2 to the app after waking up. This will help to make sure that all your data is sync properly.
Also, note that your time asleep is calculated by subtracting your time spent awake and restless from your overall tracked sleep time. For example, if you slept 8 hours but woke up 2 times for 15 minutes each, your time asleep would be 7 hr 30 min.
To learn more about your time asleep in sleep stages, see What should I know about Fitbit sleep stages?
Edit or delete sleep logs in the Fitbit app. For instructions, see How do I add, edit, or delete Fitbit data and activities?
Hope this helps.
Thanks for your reply. Something seems to be different now. For example, I got up this morning for a couple of minutes then went back to sleep for 3 hours. It would have typically included the 3 hours but it did not. Does that seem right to you?
Sent from my iPad
