03-19-2020 15:02
03-19-2020 15:02
Just wondered if anyone else has had this - with both Alexa and Spotify on my Versa 2, I log into the respective apps on the Fitbit app, and all is, briefly, well. Next time I try to use either, it tells me I have to login again. Very annoying, and means that in particular I'm not inclined to use the Alexa functionality (and in this 'end of days' scenario we're going through at the moment, I need to be talking to my watch 🤣 ).
03-19-2020 16:59
03-19-2020 16:59
Hi @woodson That sounds a bit weird. What phone are you using? (Make and model)
Try restarting your Versa 2 several times and see if that fixes the problem.
Helen | Western Australia
Best Answer03-19-2020 17:44
03-19-2020 17:44
Thanks for your reply. 😃
Phone is an iPhone 6s.
Best Answer03-19-2020 18:01
03-19-2020 18:01
That phone should work, so try the restarts
Best Answer03-19-2020 18:02
03-19-2020 18:02
K, I'll give it a shot. Thanks again.
