Versa 2 map not showing after walk
Just bought a Versa 2, and activates for instance Walk when going for a walk. Distance and all is showing afterwards in the app but not the map. It's almost as if I have autottacked the walk, not activated the exercise prior to doing it.
I have had a Versa for 2 years prior to the Versa 2, using the same phone and this was never a problem with the Versa. I have already  checked so that GPS is activated on the phone and for the exercise type.
What to do?
5 REPLIES 5
Hi @JennyU before taking off, does the Versa 2 show that it has connected to the phone GPS?
Do you get a distance measurement? With auto connect, you should not.
May i ask which phone we are asking about?
Hi.
The clock says connecting when I start the walk for instance, the phone say Connected GPS is running.
And yes I do get distance measurement.
I have an Samsung Galaxy S9+.
/Jenny
If you manually start using the walk/run mode, you will see a distance with or without GPS. You will only get a map after the Tracker has connected to the phones GPS.
With my samsung I find a phone restart gets the GPS connected.
I always start an activity manually, that has never been a problem with my Versa before.
Restart didn't work unfortunately. Any other suggestion?
/Jenny
Adding photos if that helps. Still problems after restart, reinstalling etc.
/Jenny
