08-14-2024
22:12
07:25
08-14-2024
22:12
07:25
Hi,
Versa 2 no longer syncing to app in iPhone, ALL trouble shooting steps followed multiple times, from resetting Fitbit, Bluetooth, updated app. Currently trying last option of re-pairing between Fitbit & phone, no success phone is not recognising the Fitbit.
Fitbit still works, it's the connection between the devices that isn't.
Even tried old phone, upgraded phone 2 weeks ago, no issues until now.
Thanks in advance.
08-15-2024 04:56
08-15-2024 04:56
I've got the same issue with an android phone. Its not syncing and doesn't even find the watch now
08-15-2024 07:28
08-15-2024 07:28
Hi there, @Lilah78 @Noname123123. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Versa 2 devices are still not connecting to the Fitbit app. I understand your concerns, I will do my best to help you with this!
To better assist you, please confirm you've tried all the steps provided below in the order listed:
With the steps above, what I want you to do is to pair your Versa 2 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
08-18-2024 07:11
08-18-2024 07:11
My Fitbit Versa 2 will ONLY come on & the start up “Download Fitbit app, which I have done, uninstalled & cleared all data. I haven’t used it for 4 years. I have unpaired & repaired. Frustrated.
My iPhone XR says it’s synced but the Fitbit won’t connect like it should. I wish it had a “reset button” I
08-23-2024 08:39
08-23-2024 08:39
Hi there, @_creekermo. It's nice to see you around the Fitbit Community Forums. Thanks for your time in troubleshooting the issue with your Fitbit device. I will do my best to help you with this.
As our last resort, I'd recommend performing a factory reset on your Versa 2. Important: Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc. This shouldn't affect your device as you have mentioned that you stopped using it for over 4 years.
With the above being said, please sync your Versa 2 and then, proceed with the steps below in the order listed:
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
