Versa 2 not allowing me to log in using google
My versa 2 stopped syncing. I deleted the app and reinstalled and now it won’t allow me to log in using google at all. Error message ‘something went wrong’.
11 REPLIES 11
I'm getting that too. There is something going on with the app!
Let’s hope they sort it soon. I wouldn’t mind so much if google would let
me go back to signing in with Fitbit 🤬.
I can't log in either. Although the login works fine on Web. There is something surely happening to fitbit app. Looks like someone pulled the plug and fit bit app won't restart after they plugged it back in 🤣🤣🤣
I’m having the same issue.
I thought if I disconnect my Fitbit and then re connect it that would fix it but then i couldn’t even connect a device so that backfired 😂
Then I delete the app and re-downloaded and now I can’t log in 😅
Same thing just happened to me with versa 3! So frustrated!!
A message just came up saying that they're trying to fix it
I did the same it's been like it for hours
It won't work on my tablet either
Exactly what’s happened to me.
It’s working again now so they must have fixed it.
Well fixed at last panic over
Yeah it's back on. 🙌🏻🙌🏻
Yesterday woke up to see my fitbit synced and the app up & running! So glad!
