01-26-2021
10:22
15:33
RicardoFitbit
01-26-2021
10:22
15:33
RicardoFitbit
Well done fitbit, latest update has screwed up my versa 2 after 7 months of working fine. Just like microsoft. Will not be getting another fitbit
01-26-2021
15:33
10:41
01-26-2021
15:33
10:41
Hi @Whazzman, welcome to the Community Forums.
Thanks for your post. To better assist you with this, can you please let me know in which way is your Versa 2 not working after updating the firmware version? Please share as many details you can so we can move on.
Looking forward to your reply.
01-28-2021 04:19
01-28-2021 04:19
I have the same problem; it will no longer sync with the app. I’ve restarted the watch and phone, which usually helps, but it still will not sync. I turned Bluetooth on and off, and it still doesn’t work. I then forgot the versa2 connection in my Bluetooth settings, and now the Versa refuses to reconnect with my phone.
This happened to me on Tuesday 26 Jan 21 as well.
You’re probably going to suggest a factory reset, correct?
01-28-2021 06:55
01-28-2021 06:55
@MizarkMost definitely not.
There's a bug in the last Fitbit App update for Android phones which stops phones syncing, Hopefully they will issue a fix soon. In the meantime if your watch works it will keep data for about a week and best to not make any changes till its fixed.
Best Answer01-28-2021 07:32
01-28-2021 07:32
I am having the same problem..After the latest update ..My Versa 2 is not working properly..It turns off then right back on all the time ..As well it doesnt track my workout properly anymore and it will stop my workout timer I have this watch for a year now and work perfectly fine until the latest update..
01-28-2021 15:20
01-28-2021 15:20
Thank you Guy. I'll hang tight.
Best Answer01-28-2021 15:29
01-28-2021 15:29
I suspect the bug is really in the Versa. I say this because I turned off Bluetooth on my phone and tried my Windows 10 machine. It will not pair any longer. This started very close to the time of the Versa update. Note: I have a Versa "original". I am trying to get this comment to the dev team at Fitbit but not sure how to go directly to them.
Best Answer01-28-2021 15:42
01-28-2021 15:42
I have a Versa "original" not the Versa 2 but maybe this info will help. My Versa stopped syncing about the same time as the last Versa update. I also have the new Android App v3.37. I'm thinking the issue may actually be in the smartwatch. I shut off my phone and turned on Bluetooth on my Windows 10 machine. The Windows UWP app is no longer able to sync with the Versa. I have tried all the "quick" fixes like restarting the Versa, etc. Then I took the drastic measure of resetting my Versa to factory and removing it from the account. I did a "set up device" on the Android app. All was well until it did the update to the Versa. At that point the app stayed in "installing" mode for a couple of hours and neither app (Android or Windows 10) is able to connect to the Versa. Hope this can help the dev team debug the issue.
Best Answer01-28-2021 16:39
01-28-2021 16:39
Factory rest didn't help me fix the problem only made me lose all my info.
Best Answer01-30-2021 10:25
01-30-2021 10:25
Good afternoon Guy. I just updated the app and the phone and watch instantly connected and everything sync'd.
Much appreciated!
Best Answer04-01-2021 13:07
04-01-2021 13:07
Same thing here. Took me 2 hours of trying to get the fitbit and app to reconnect. Now I need to reboot my fitbit multiple times a day in order to sync. Since the "update" Versa 2 no longer auto tracks my walks. I need to take my phone along and use GPS in order for my V2 to track the walk. Today, it cut off the tracking before the end of the we walk though it did count the time correctly.
Fitbit seems to be making life miserable for users in order to force us to upgrade to a newer model. I'm more likely to upgrade to a newer brand! I'm getting tired of having to buy a new fitbit because it updated me into not working when it was working really well beforehand! Why, Fitbit?
Best Answer04-01-2021 13:09
04-01-2021 13:09
Fitbit doesn't seem to care. Still same problems with this update that people were experiencing in Jan. ::sigh::
04-01-2021 13:33
04-01-2021 13:33
@move2improve The Versa 2 doesn't have onboard GPS. A phone was always needed to track walks.
Best Answer04-01-2021 21:44
04-01-2021 21:44
Best Answer04-01-2021 22:57
04-01-2021 22:57
I have the identical problem, please help
Best Answer05-09-2022 18:16
05-09-2022 18:16
Same thing happened to me. I just held off doing it until yesterday, and now my watch doesn't work.
Best Answer05-09-2022 18:22
05-09-2022 18:22
Hi Ricardo. I hope you can help me. I have the versa 2. I did the firmware update yesterday. (If you let me know how to tell you what version, I will happily do so)
Can you help?
