12-03-2020
01:20
13:51
RicardoFitbit
12-03-2020
01:20
13:51
RicardoFitbit
I have a new Fitbit Versa 2 which have worked fine with my Huawei P30 Lite for the first 4 days of use and then stopped receiving notifications. It is connected, I have already tried to restart Fitbit and Phone, to switch the Bluetooth off and on and I have already checked the How do I get notifications from my phone on my Fitbit device? page with no use. It does not receive notifications. I have tried the test phone call and it works but notification don't.
The Fitbit app acknowledges a problem with notifications and suggest to restart the phone, which I did (twice) and it still show the same message and the notifications still don't work.
If it keeps not showing notifications I will have to return it since it is no use to me this way.
12-06-2020
13:51
12:40
12-06-2020
13:51
12:40
Hi @Flaviav79, welcome to the Community Forums.
Thanks for bringing this to our attention and for trying some troubleshooting steps before posting over here, I understand how frustrating this matter can be for you. Since you already tried the troubleshooting steps from the help article that was specified in your post, I recommend you to check and try the ones that are listed on: What should I know about using the Fitbit app on my Android phone? and let me know if the issue persists.
I'll be around if further assistance is needed.
Moderator Edit: Content
Best Answer12-06-2020 23:59
12-06-2020 23:59
17:28
12:39
12-07-2020
17:28
12:39
You're welcome @Flaviav79, your reply is also appreciated.
I'd like to begin this post by apologizing with you for the mistake made on my previous post, the information I shared was about the Huawei P20 Lite and not the P30 one. Actually, I'm using the same phone as yours but with a Fitbit Ionic with no trouble at all. Let me share with you that some mobile devices/tablets are not compatible with our products and services because of the Android/iOS version they're running and because of some other software specifications, however, since your phone does met the requirements to properly operate with your Versa 2, please try the troubleshooting steps that were shared on my previous post and let me know if the issue persists.
By the way, I'd like to let you know that some information of my previous post will be deleted to avoid confusion with other users that are participating in our Community Forums, your understanding and patience are appreciated.
I'll be waiting for your reply.
