09-12-2019
20:37
07:01
LizzyFitbit
09-12-2019
20:37
07:01
LizzyFitbit
I have a Versa 2 and an iPhone X and cannot seem to get my text messages to my watch. All the settings are on to receive notifications on phone & watch. I had no issue with this and the blaze. Help please:)
02-16-2020 08:34
02-16-2020 08:34
I have a Note 10+ & had the same issue - not receiving text on Versa 2.
Here's what worked for me after reading 1/2 of the comments here.
Make sure in the in-app settings for Messages the Preview Messages is on.
Under Adaptive Notifications, Notification Access, Fitbit should be on.
Go to App Notifications on your Android, under Recently sent look for Fitbit. You may have to click on SEE ALL. Click on Fitbit, make sure notifications are ON. Scroll all the way in the bottom, go to in-app notification settings. Make sure that Messages are on.
I also uninstalled Fitbit & reinstalled it. Reset my Versa 2 under settings, about, shutdown. Reset my phone Unpaired Versa 2 from my phone's Bluetooth. Once Fitbit was reinstalled on my phone I put my Versa 2 in Trash and re-added the device in the Fitbit app.
After all this I'm happy to say that I'm getting text messages now on my Versa 2. Hopefully, this helps.
02-16-2020 08:40
02-16-2020 08:40
Have you contacted Fitbit directly by email? I have an Android so I can't help. But they answer pretty quickly within a day. I find it better than these Forums. Mine has been working well all of a sudden after a sync. Fitbit can see what's in your phone.
Best Answer02-22-2020 07:01
02-22-2020 07:01
My Versa 2 will receive calls but not text messages.
Best Answer02-28-2020 22:09
02-28-2020 22:09
I’ve tried everything! I emailed them several times. They keep sending me the same articles I have found online and are no help. Terrible customer service! I guess I will buy an Apple watch.
Best Answer02-29-2020 00:06
02-29-2020 00:06
Fitbit keep saying it's a known problem and they are trying to fix it but after 5 years with fitbit, I've had enough. I've wasted £200 on something that doesn't work. I'm swapping to samsung from now on
02-29-2020 09:17
02-29-2020 09:17
Best Answer02-29-2020 09:18
02-29-2020 09:18
Yes. I am so very disappointed in their customer service. They will lose a lot of customers over this. And will not give me a number to call
Best Answer02-29-2020 09:21
02-29-2020 09:21
Best Answer03-01-2020 14:21
03-01-2020 14:21
I’m having the same issue. Did you ever get it resolved?
Best Answer03-01-2020 14:37
03-01-2020 14:37
I did get the issue resolved. Had to put notifications for messages on always preview. (Which I don’t like because it also previews on my phone.).
03-01-2020 14:44
03-01-2020 14:44
it also works when you put it on preview when unlocked. I don’t like previewing my messages either. At least like this it’s not showing up for everyone to read.
03-01-2020 15:53
03-01-2020 15:53
Best Answer03-07-2020 11:13
03-07-2020 11:13
Make sure your iPhone settings floor messages is set to Settings>Notifications>Show Previews>Always. That worked for me too.
03-10-2020 18:51
03-10-2020 18:51
I haven’t had another watch but no matter what I change I can not get text messages on my Versace 2. I reset everything a second time. ( I have an iPhone X
Best Answer03-10-2020 19:01 - last edited on 04-20-2020 17:56 by LiliyaFitbit
Hi,You need to enable your messages to display on your screen. Under notifications: messages: options: show preview: always or when Unlocked.
But keep in mind this will also mean that the text of your messages will display on your iPhone.
Hope this helps.
Anna
03-10-2020 20:31
03-10-2020 20:31
Thank you. But mine has been working for weeks now. I have an Android not an IPhone. From what I understood the IPhones had the most problems. Thank you anyways. Hope your answer helps the IPhone users.
Best Answer03-10-2020 20:34
03-10-2020 20:34
I have an Android phone. If any of the suggestions on here won't work for you. I would suggest contacting Fitbit Support by email. It will give you a case number and they can track how your phone is set up. https://contact.fitbit.com
Best Answer03-11-2020 10:05
03-11-2020 10:05
Best Answer03-14-2020 13:54
03-14-2020 13:54
Thanks for this information. I can get my text messages but can't type a reply or do a quick reply. Are you having this problem?
Best Answer03-14-2020 15:18
03-14-2020 15:18
I really haven't sent a reply that way. I have only marked it READ and it comes up on my phone that way.
