Versa 2 not starting after factory reset
I wanted to reset my versa 2 so I could give it to my partner since I dont use it anymore.
I did the settings - about - factory reset way.
Now it will not start up again.
Pressing any or all buttons does nothing, I left it in the charger all day.
Send help 🙂
4 REPLIES 4
Try a Restart and do it several times if necessary.
È successa la stessa cosa a me.
Dopo aver effettuato un ripristino fabbrica non si è più riacceso, esce solo il logo fitbit che chiede di istallare l'app su Play store e non va oltre.
It does not respond to any kind of combination of buttons I press and hold.
It also does not show up when connected to a laptop. Makes connecting and disconnecting sounds non stop.
