11-02-2019 09:30
11-02-2019 09:30
I just went from a Charge 2 to the Versa 2. Since changing over, my Versa 2 will not track my sleep. It's showing like 1hr per night, but nothing else?
It is tracking steps and my heart rate just fine though.
01-14-2020 07:14
01-14-2020 07:14
Best Answer01-14-2020 07:51
01-14-2020 07:51
Add me to the list of people with this issue. I had the Alta HR and it recorded my sleep perfectly straight out of the box for over 2 years. I've tried all the updates, resets, etc. and I get no sleep records at all - "no score". The sleep feature is just as important to me as the activity, and way more important than being able to "Ask Alexa". Let's get core functionality working before we add a bunch of nonsense like a Starbucks ap.
01-14-2020 08:15
01-14-2020 08:15
My Versa 2 is also not tracking sleep. This has happened before for 1 night but now for the last 2 nights it hasn't tracked sleep. I find a lot of issues with this unit. I spend more time trying to "fix" it (I've only had it since after Christmas). Weights and measures change by themselves and I have to go back in and try to remember what I entered and re-entered. Getting ready to give up on it!
01-19-2020 06:50
01-19-2020 06:50
I had the same issue with this product not recording sleep, recording it for 2 days and then stopped completely. Done all the things reported on this forum. I have also had issues where the workouts are not recorded, Bluetooth disconnects, entries are not retained, etc. I received for Xmas and hoping I can return bc I spend more time troubleshooting and fixing rather than enhancing my lifestyle. I was so excited about this product but it really should work out of the box.
01-19-2020 07:41
01-19-2020 07:41
01-19-2020 09:20
01-19-2020 09:20
I've used a few fit bit devices in the past 10 years. Even when they weren't wearables and had to put it in your pocket. I've had the versa2 for around 6 months now and it's probably been the most unreliable one in tracking sleep. Sometimes it's sporadic and won't track one day in a month but somtimes it'll miss 2 days or more in one week. I might end up throwing it out the window.
01-19-2020 09:37
01-19-2020 09:37
Best Answer01-22-2020 01:15
01-22-2020 01:15
Just wanna chime in here and say I'm having the exact same issue as many here with my Versa 2. It tracks sporadically and I don't know why. Most nights it says I'm getting 2hrs thereabouts, whereas last week it tracked pretty well, there's no consistency. Oddly, it tracked exactly 2hrs16min exactly for the last two nights. Wholly inaccurate and very disappointing 7/10
01-26-2020 06:14
01-26-2020 06:14
It won't give you a sleep score if you actually hit sleep in the app. Idk why but it just doesn't
01-31-2020 08:49
01-31-2020 08:49
I'm curious, is this still a problem for you? I have contacted Fitbit several times regarding this sleep issue with the Versa 2 and they want to keep referring me to articles on how to properly wear the watch. I've had a Fitbit for years and never had this problem with my previous watches. They clearly don't think they are at fault nor do they care to stand behind their product.
01-31-2020 08:52
01-31-2020 08:52
01-31-2020 08:54
01-31-2020 08:54
01-31-2020 08:57
01-31-2020 08:57
So, I actually did get it working this week. But thats from tightening the band so it doesn't move. Then keeping on the inside of my wrist during sleep and turning on the app to begin sleep now.
The begin sleep now will be overwritten by the watch if it syncs correctly. This has been working this week. And since three of us our now confirming it working a little bit better, I'm guessing they sent an update out and don't want to admit to a faulty product.
Cause I was in contact for an entire month and it never worked with anything that they gave me at the time.
Best Answer01-31-2020 08:58 - last edited on 01-31-2020 13:59 by LiliyaFitbit
Hi
Yes fixes it myself too
I got a replacement Fitbit Versa 2 and now wear it on the inside of my non dominant hand. I don’t tell it I am going to sleep. Just let it Auto detect sleep. When I wake up I have a shower before I check data. It all seems to work. Occasionally it does have a data sync issue but if I leave it it corrects itself
Best Answer01-31-2020 09:00 - last edited on 01-31-2020 13:59 by LiliyaFitbit
Hi
I have replaced mine and it all works. Just let it auto detect data. Not used the add water so can’t help with that.
Best Answer01-31-2020 09:02 - last edited on 01-31-2020 14:00 by LiliyaFitbit
Best Answer01-31-2020 09:11
01-31-2020 09:11
Best Answer01-31-2020 09:32
01-31-2020 09:32
Best Answer01-31-2020 09:36
01-31-2020 09:36
01-31-2020 09:36
